Previous in Forum: Bearings   Next in Forum: Wafer vs Lug Type Butterfly Valve
Pipe Bend Redius Calculation
11/17/2010 5:52 AM
I want to calculate the pipe bend redius for 5D bend of main steam pipe (570^ C temp., P91 material) It is a ID base pipe and pipe ID is 340mm. Pipe thickness is 68mm (MWT). How to calculate the bend redius.
Good Answers: 137
Re: Pipe bend redius calculation
11/17/2010 7:39 AM
For a 5D bend the bend radius (to centreline) is nominally 5 x diameter, but I don't know offhand whether that is 5 x ID, or OD or nominal dia. I suggest you look in a catalogue, or contact supplier, or go out and measure it.
Cheers......Codey
Re: Pipe Bend Redius Calculation
11/18/2010 11:21 AM
Boy, that is some heavy pipe!
Good Answers: 61
11/18/2010 11:32 AM
The "D" in a 5D bend or any other Bend refers to the "Nominal Pipe Size".
Therefore a "5D" Bend in 6" pipe has a 30" Radius.
It would work the same for metric sizes to.
Do it once and do it right
Codemaster (1); PennPiper (1); Tornado (1)
