I want to ask again about the same motion sensor device I did a few days ago. First I tested the device on the bench and it worked perfectly (I changed the faulty transistor that drives the relay). Then I installed the device on the wall and the lights turned on and never turned off. This time I looked first at the transistor and then at the relay, both are ok. Now I unsoldered all the pins except 2 of the IC that drives the transistor. One pin I left connected is Vcc ( 5V) and the other goes to the basis of the transistor that drives the relay. At this pin I can see about 4V and after a resistance between that pin and the basis 0,67 V and the lights turn on.
So it must be the the IC (that is what I think). Does anybody know something about this IC? ICES49H. It is not the LM324 as I could find in other motion devices.
I looked all over the internet for a datasheet of this ICES49H and the only thing I know now is that I can order hundreds of this IC's in China. What should I do with all these little circuits?
