Previous in Forum: How can I post my product catalogue in my Globespec for free?   Next in Forum: About UT Testing
How to Maintain Hydraulic Cylinder?
11/20/2010 3:17 AM
Before demolition of hydraulic cylinders,should make hydraulic loop.then discharging pressure.Otherwise,when fuel tank to link the pipeline joints and loosening,loops of hign oil will be quickly ejected. when hydraulic circuit relief pressure,it should loose handwheel at overflow valve and other places or regulator screw,to make pressure oil load-off, and then cut off the power or disconnect the power source, to make hydraulic device stop operation.That's right?
Good Answers: 37
Re: How to Maintain Hydraulic Cylinder?
11/21/2010 1:34 AM
I'm sorry, "Sinomould". I can't understand your question. Are you trying to translate from [Chinese?] into English? Can you find a native English speaker who can translate for you? Or, tell us what language you speak, and ask here (CR4) for someone to contact you to translate.
" Ignorance and arrogance have more in common than their last four letters. "
11/21/2010 3:05 PM
I ran this through the LynDoor™ Intergalactic Multi-Lingual-Translatorium® analyzer.
It says, "is it wise to relieve the hydraulic system pressure prior to cylinder dis-assembly"?
LynDoor™ listens.
Good Answers: 37
11/22/2010 8:45 AM
"I ran this through the LynDoor™ Intergalactic Multi-Lingual-Translatorium® analyzer."
[Is that the one you abbrev. to "LIMLiT", for how it shows up every nuance in the bright glare? Just asking . . .]
I normally just use the Babel Fish in my ear, but he (she? it? they [hive mind]?) was sort of lethargic that day. Probably just hasn't gotten enough exercise after quite a few posts which were already easy to read without his (her? its? their?) help.
Anyway, relieving system pressure and cutting power to the equipment is more than just a good idea: it's the key to survival in that environment.
Good Answers: 74
11/22/2010 5:45 PM
If your knowledge of hydraulics is at par with your language skills I can only make one suggestion: sit still and do nothing until you get your question right. It can kill you otherwise!
No, there is no space for experimenting, that's right!
The Twain Has Met
Register to Reply 4 comments
ky (1); lyn (1); Ron (2)
