Previous in Forum: Induction Motor Impedence   Next in Forum: Capacitor Banks on Generators Needed or Not
What is the Material of Corona Ring ?
11/20/2010 8:02 AM
What is the material of corona ring ? A 380 aluminum die cast aluminum alloys or not
Good Answers: 27
Re: What is the Material of Corona Ring ?
11/20/2010 11:04 AM
It depends on the corona (grading) ring design and manufacturing process. Die cast are usually 380, sand and permanent mold 356 or A356, and fabricated rings are usually made from 6061 thin wall tubing or pipe that is formed and welded; with appropriate brackets and other mounting provisions.
11/20/2010 12:31 PM
Is the chemical composition of high voltage corona ring important for electrical conductivity etc. ?
Good Answers: 27
11/20/2010 11:52 PM
No. It just has to be conductive and bonded to the energized (or grounded) electrode which it is grading. Their function is to increase or expand and reshape the geometry of energized (or grounded) end caps, etc. and smooth the electrostatic field, thereby reducing the voltage gradient on those surfaces to a level below the critical ionization gradient of the surrounding air or other media.
More properly, they are voltage grading rings that also serve to grade the voltage of the insulator, surge arrester, bus clamp, etc. and reduce the overall voltage stress by increasing the coupled capacitance to the surrounding voltage field.
Aluminum is most commonly used for corona rings because of its light weight, relative ease of casting or fabrication, cost and availability but other metals can also be used.
11/21/2010 2:45 AM
Corona is made by fermentation of wheat,sugar like any other beers. Yes It is available mostly in glass bottles and aluminum cans.
Anonymous Poster (1); Bluestone (2); erdalkudret (1)
