Previous in Forum: 3 MVA-Distribution   Next in Forum: Desalination Plants
9 comments
3rd, 5th and 7th Harmonics Analysis
11/21/2010 6:26 AM
how to do the 3rd, 5th and 7th harmonics analysis....can any one show me the easiest method for harmonics distortion studies...
Thanks,
There are no shortcuts on the road to a great experience.
Re: 3rd, 5th and 7th harmonics analysis
11/21/2010 11:51 AM
I recommend that you start with an understanding of the mathematics of a Fourier transformation. In your study you should find that if you use a binary power of data samples (2n) that you can now perform a Fast Fourier Transform (FFT). This will give you a grasp of what harmonic analyses are telling you and which assumptions must be taken to do an FFT analysis.
Good Answers: 244
Re: 3rd, 5th and 7th Harmonics Analysis
11/21/2010 2:25 PM
11/22/2010 4:37 AM
Go to engineering college
or
Send me a DD for 2000 Dollar
11/22/2010 12:11 PM
CR4 is my college...:D
saaly desmond ki najaiz aulad..harami pan chor.
11/22/2010 1:10 PM
I'm flattered that you learn from our discussions. A formal college education will give you much more knowledge than what CR4 can give. You will also get credentials to go with your new knowledge. If you possibly can, get yourself a formal education.
"Knowledge is more important than wealth. You have to look after wealth; knowledge looks after you."
- Imam Ali (ra)
11/22/2010 1:33 PM
Thanks for your lovely comment....cheers Guru :)
11/25/2010 3:57 AM
CR4 Admin - Deleted Comment
This post was deleted because it contained an attack on another user.
11/22/2010 10:16 AM
The easiest method is to use a Frequency Analyser instrument. The study material appears on the screen or, in some pieces of equipment, on a print-out as well.
11/22/2010 12:33 PM
PWSlack thanks and agree with you,I have to use Harmonics Analyser to know the actual distortion in frequency.
or I can use any software for harmonics simulation.but for that also we need to know all the non-linear loads in the network like AC drives,switchings,lightings etc which can produce harmonics.
Thanks
Register to Reply 9 comments
Anonymous Poster (2); Aseer (3); msamad (1); PWSlack (1); redfred (2)
