Previous in Forum: Thermostatic Mixer Shower - Bar Pressure and Water Flow Question   Next in Forum: Document About Cat Pump
Pipeline Fittings
11/21/2010 6:37 AM
i am given a pipeline having following specs
pipe material API 5L Br.B
SMYS: 241 MPa Maximum Allowable Tensile Stress:
Design Pressures: 725 psig
Operating Pressures: 290 psig
Minimum Operating Temperature: 0 ˚C Maximum Operating Temperature: 50˚C
plz can someone guide me how to select the flange & ball valve for this pipe
Re: pipeline fittings
11/21/2010 9:56 AM
Saheeb...
You have some problems...
The first problem is, of course, you do not understand the concept of piping line specifications, piping engineering and design.
The second problem is a large difference between the operating pressure and the design pressure in this piping system
Valve ratings and flanges are selected based on design pressure, not operating pressure.
You will be selecting and purchasing much more expensive valves and flanged components based on a design pressure of 725 psig. ( probably class 900).
If you were to use a more realistic design pressure of 325 - 350 psig, a more realistic pipe clas ( say Class 300) could be purchased.
11/22/2010 2:11 AM
And I believe you do not know what is the ANSI pressure rating. For the design pressure of 725 psig at 50°C you can use ANSI 300# pressure rating
Good Answers: 25
Re: Pipeline Fittings
11/21/2010 11:07 PM
What? More homework, look at the specs. If that fails and you can select an or equal from the Engineers references for pipe and valves. Clearly you are not qualified to have any control over the work as you can't even tell us what the nature of the material that will pass through the pipe/valve consists of. I suggest that you enroll in a different course, possibly basket weaving and left over beer straining.
TMF
The only problem with common sense, is that not very many people have it, or know how or when to use it.
11/22/2010 1:57 AM
pipe fittings and erection
11/22/2010 10:19 AM
What is the pipe wt? What is its OD?
11/22/2010 12:10 PM
In pipelines, normally we do not use flanged valves, we prefer welded valves on line, rated at design pressure.
Register to Reply 6 comments
Anonymous Poster (3); ferdy (1); surbhirana (1); Toomuchfun (1)
