Previous in Forum: Corrosion Coupons, Minimum Corrosion Rate Calculation   Next in Forum: Partical Bed Explanation of the Brazil Nut Effect
Acid Pump
11/22/2010 7:58 AM
what is the function of the magnetic in the acid pump
Re: city
11/22/2010 8:27 AM
Don't know what it is you are trying to ask, Rule #75 is alive and well.
The crystal ball says, "it couples the motor to the impeller".
Get some help asking the question next time.
Good Answers: 38
Re: Acid Pump
11/22/2010 2:34 PM
Please get someone to help you with your English..
Let the guessing games begin !!
Are you talking about "Mag-drive" pumps used in acid service ?
Something else, perhaps ?
Re: Acid Pump
11/23/2010 3:19 PM
A Mag Drive pump is a type of sealless pump that utilizes a magnetic coupling to create a static shaft seal. Magnetic force aligns the outer magnet (drive magnet) and inner magnet (driven magnet) through a stationary containment shell (canister). This eliminates the hazards and mess caused by packing or mechanical seal failure.
lyn (1); MJCronin (1); philroth2252 (1)
