I am preparing a procedure for using corrosion coupons on the cooling water cycle. I referred to the following references: NACE Standard PR0497, ASTM G 1, ASTM G 4, ASTM D 2688, ASTM D 2331, and NACE RP0392.
I have 2 questions:
1- What is the acceptance criteria for the calculated corrosion rates for carbon steel, stainless steel, and copper coupons.
2- What is the minimum detection limit for the corrosion rate calculations. I mean sometimes the corrosion rate equals 0.000X mpy, in most measuring methods a preset minimum value is used if the calculated one is smaller.
