Previous in Forum: How Ductile is Iron?   Next in Forum: Will Bolts Be Significantly More Brittle in Moderately Low Temperatures?
Evaporation Pond with Surface Aerators
11/23/2010 3:16 AM
Sirs
i hve water flow rates 50,000 bpd i need to design an evaporation bond with Surface Aerators , kindly could you help me to give me the dimensions of this bond . and the basics for this design .
regards
ismail shoukry
egypt
Good Answers: 101
Re: Evaporation Pond with Surface Aerators
11/23/2010 3:35 AM
What do you mean by bpd? Barrels per day? Or do you mean to say gpd, gallons per day? If so, do you mean US or Imperial gallons? Also, do you mean evaporation pond, not bond? Finally, what exactly is the purpose of this pond, and what do you need the aerators for? Please answer all these questions first, otherwise we won't be able to answer your questions for you.
Reply to Forum Thread
