Previous in Forum: Increasing Power Output of 4 Stroke IC Engines   Next in Forum: 4x4 vs. Studded Snow Tires
Air Leak Test Equipment
11/23/2010 6:44 AM
can you send me some draft about air leak test connection equipment with suggestion specification for make this test for reinforcement plate which was installed on pipe,so that i know that the pressure should to be 1 bar or 15 psi
thanks a lots
Re: Air Leak Test Equipment
11/23/2010 7:53 AM
Can you draft a coherent question?
Thanks.
12/01/2010 10:58 PM
it is difficult to understand the information you quest after. what is the type of material the pipe and fittings or fittins as they say in the field,are made of, and what is it being used for. is it above or below grade. come on dude i know you can do it.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
