Previous in Forum: city   Next in Forum: Mechanical Design of Swimming Pool
Trunnion at Saddle Region
11/23/2010 8:24 AM
hi to all engineer and designer and fabricator,
I am searching for an opinion about the possibility to place a bolted trunnion at the saddle to facilitate lifting the heavy horizontal vessel since logically it is the best choice the to place the trunnion.....
if anyone have an experience, your reply will be much appreciated...
rise and rise again...continue to learn is nothing wrong
Good Answers: 38
Re: Trunnion at Saddle Region
11/23/2010 11:27 AM
A sketch or picture would help much.
Will the vessel need to be installed in the vertical or horizontal position ?
Usually, two or more trunions or lugs are used.
Usually they are welded, not bolted and remain on the vessel permanently.
How heavy is the vessel ?
11/23/2010 12:56 PM
hi, in my case of horizontal vessel weighing almost 350 ton and in diameter of 7m and 25m length...and I was thinking that it will be better to lift the equipment at the saddle since I have reinforcement in saddle region rather than risking deformation of the shell when lifting...
Good Answers: 38
11/23/2010 7:52 PM
This is a significant major lift.
Errors could be very expensive an possibly deadly.
If you have never done this before and you are looking for advice from strangers on an internet forum, you are in big trouble.
Pay for a experienced structural professional
11/23/2010 8:54 PM
Not knowing the structure of your final housing/mounts. Many large tanks are placed by means of lifting slings placed near the saddles. These sling the impact of lifting and reduce the structural engineering cost of single point lift attachments. Many of the crane company's can assist you with your needs if you provide the proper information to them. Trunnion works but it sounds like you are not making a mobile item but a stationary one.
Register to Reply 4 comments
Anonymous Poster (1); MJCronin (2); philroth2252 (1)
You might be interested in: Lifting and Rigging Attachments, Lifting Jacks
