Previous in Forum: Is Pocket in the LPG Booster Pump Suction Line Acceptable?   Next in Forum: Trunnion at Saddle Region
city
11/23/2010 6:32 AM
hello every body. yesterday I asked question and I got reply from some and others said they did not understand what I mean I will repeat for them my question again .
one said I have to ask for help in english I will said to him sorry I Know what I want to write may be it is difficult for you to understand so you need to ask for help in english
in power plant there is a chemical plant and of course they used acid (H2SO4) and there is acid unloading pump and inside the pump there are permenent magnetic plate connected with the impler and one is outside the pump with the shaft of the motor .
why they are using magnetic to rotate the I mpler and did not use the motor shaft direct coupling with the impler
5
Re: city
11/23/2010 6:37 AM
It's so that there is no shaft seal for the acid to leak through when something goes wrong.
Magnetically-coupled pumps are ideal for agressive liquids handling, and are widely available.
Reply Good Answer (Score 5)
Re: city
11/23/2010 7:20 AM
So you are saying that instead of coupling they or using this magnet. Is it correct???
Good Answers: 243
Re: city
11/23/2010 10:17 AM
Yes he is.
Milo
Re: city
11/23/2010 10:58 AM
This is to prevent leakage of corrosive, toxic, or highly valuable fluids through what would otherwise be a shaft seal or packing. The pump impeller is inside a "can" and has magnets built into it. The motor drives a matching array of magnets outside the can.
Milo (1); Natarajan (1); PWSlack (1); Tornado (1)
You might be interested in: Lead Acid Batteries, English Pitch Timing Belts
