Previous in Forum: Heat Insulation   Next in Forum: Project on Environmental Engineering
Steel Reinforcement in RC Beam
03/21/2007 12:21 PM
I am a new civil engineer but very limited in some areas of this field. Hence, I will love to appear for your help with my professional problems.
How does one calculate the steel reinforcement (type, size, shape) of a Concrete beam, of the dimension (B=0.3m X H=0.5m) 6 meters long, which is simply supported on both ends.
Re: Steel Reinforcement in RC Beam
03/22/2007 1:47 AM
Though I am not a civvy like you, I still think you need to specify the application before approaching designing................?
03/22/2007 7:13 AM
What type and amount of loads are acting on the beam?
03/22/2007 7:20 AM
Recommend you go back to university and study basics in structural elments of materials.
03/22/2007 8:49 AM
You have seen/felt the 3 responses--but I shall tolerate your lack of specifications.--and try to guide you.
What load do you expect to carry?
  • Distributed : Say "1 Ton per sq meter warehouse first floor 6x4 meter and continuously like that.every 4 meters"
  • OR Random live loads--people+ general funiture on a conctrete solid slab 5" thick
  • OR 2 of your specified beams 2.5 meter apart supporting a conrete reinforced deck-and to carry light passenger cars one way..
  • SAY what?
And again-why did you specify a Cross section 0.3x0.5m at all?Why not 0.5 wide by 0.3 m deep Or why not I section 0.2(0.1 rib)x 0.6 deep? Don't you actually calculate?
Do you know why a Steel H Beam (with flanges top and bottom i.e turned 90°)is a better/ rational shape?
Do you know that there is no need of steel on the top flange of RCC beams--and no concrete to cover the tensile steel members - which should be at the bottom?
Reply all these.
Everybody will THEN teach you if you are not sure of what/how you should apply >> what you learnt at your Engineering college.
Anonymous Poster (1); hmuratmercan (1); MUKULMAHANT (1); Nachi (1)
