Previous in Forum: Pressure Relief Vent   Next in Forum: Type of Motor for Spark Proof Fan as per AMCA Class B
Performance Evaulation of Condensing System
11/24/2010 10:53 AM
Q 1: How a surface condenser for steam turbine can be checked against fouling during operation? Any particular formula or method.
Q 2: How to evaluate/check that liquid Ring vacuum pump is functioning properly during operation of steam turbine? i.e what parameters shows its performace?
Q 3: What are the methods for leakage test of surface Condensor from steam side during maintenance? i.e back filling from hotwell. any other ?
Good Answers: 38
Re: performance Evaluation of condensing system
11/24/2010 11:17 AM
Q1: Check/compare the temperatures and flow rates during operation versus the original HEI design datasheets......You did keep these, right ? Hopefully they were not thrown away by the previous political regime. Have accurate gauges.
Q2: Check the final vacuum achieved versus the design data sheets mentioned above. You should have in your possession expected vacuum levels versus cooling water temperature curves. ( Do you have any plant records at all ?)
Q3: Leakage testing of large steam surface condensers is commonly done by Helium Leak testing during operations. A wand is used and the entire condenser surface is "scanned". Where a leak occurs devices signal that there is heliem leaking. This is best done as a contracted service
Reply to Forum Thread
