I have recently encountered a 33kV tape joint failure due to insufficient insulation tape thickness at the point of failure.
The overall insulation tape thickness was only about 10mm on the side where the failure occurred. The instruction manual says a 15mm thickness. What I don't understand is, why the bottom portion of that joint has a thickness of 10mm but the top portion has 30mm, whereas the taping is done circumferentially? Below is the cross section showing the big difference:
As the jointer would normally measure the overall O.D. to determine that he has achieved the required insulation thickness, he wouldn't be able to foresee such big difference in thickness on different sides of the joint. I initially thought that this may be due to inconsistency in tape stretching by the jointer but is it true that the inconsistency can lead to such big difference? Anyone has encountered such phenomena before? Any thoughts?
