Check valve has two openings in the body, one for fluid to enter and the other for fluid to leave. There are various types of check valves used in a wide variety of applications. Wafer Single Plate Check Valve is those that are designed to fit between a set of flanges. Both lift and swing check valve is bulky and costly. To overcome this, wafer check valves have been developed.
