Previous in Forum: Diffrancial pressure   Next in Forum: Booster Pump Operating Point
Crawler crane
11/26/2010 1:45 AM
Hi, I have seen a crawler crane specification which mentioned that Max. Lifting capacity of crane boom is 250t x 4.6 m. Please clarify about this 4.6m. Thanks in advance
Good Answers: 101
Re: Crawler crane
11/26/2010 2:15 AM
Distance of load from crane c.g.
Re: Crawler crane
11/26/2010 5:08 AM
Thank you for your reply. It might be my homework but i don't know how to get the answer. Please clarify. Is it vertical or horizontal distance(regarding your answer)?. I will show two type of configuration of a crane. 1. Crane boom (max. lifting capacity 250t x 4.6m, max. boom length 91.4m) 2.Long boom (max. lifting capacity 47.1t x 12.4m, max. boom length 91.4m). Here i want to know about the diff. b/w 4.6m & 12.4m.
Re: Crawler crane
11/26/2010 5:15 AM
Horizontal.
"Here i want to know about the diff. b/w 4.6m & 12.4m."
The diff. b/w 4.6m & 12.4m is 7.8m.
Man, you're really lucky. I just got up to pee and saw your question. Glad I could help!
Re: Crawler crane
11/26/2010 7:08 AM
Yes the distance from the center of the pin and the C of G (Center of Gravity) of the load. The further your C of G on the load is from the center of the crane pine the lifting capacity decreases. Refer to Crane chart for value on capacity at a given distance. Essentially a proportion question.
Polyoxymethylene (POM)
11/26/2010 6:54 AM
CR4 Admin Deleted Post Reason: Spam
DVader1000 (1); lyn (1); Natarajan (1); pipeit (1); shahpolymers (1)
