Previous in Forum: Twisting of Geometry   Next in Forum: Crawler crane
16 comments
Diffrancial pressure
11/25/2010 1:52 PM
What is diffrancial pressure aod how we will measure it for bag house
Re: Diffrancial pressure
11/25/2010 1:55 PM
How about a manometer.
11/25/2010 2:31 PM
Bag House
for Bag Puss
Website for this image
smallfilms.co.uk
Size:372 × 278
Type:25KB JPG
11/25/2010 2:32 PM
smallfilms.co.uk
Size:372 × 278
Type:25KB JPG
11/25/2010 3:24 PM
Stub,
Is that you?
11/25/2010 3:51 PM
I'm not sure what the aod stands for (is this a steel mill application--maybe an "AOD (Argon Oxygen Decarburization) unit for refining specialty steels"?
But differential pressure is the difference between the pressure on two sides of--in the case of a baghouse, the filter bags. It is an indication of how dirty the filter bags are.
As lynlynch suggested, a manometer can do the job for a local reading. For a remote reading, a differential pressure transmitter will do the job, or for just giving an alarm, a differential pressure switch will do the job.
11/25/2010 3:56 PM
rhkramer,
Your mind reading skills are better than mine.
11/25/2010 7:37 PM
Good Answers: 137
11/26/2010 5:58 AM
Agreed, and if he wants to do it cheap, for the ΔP likely with a bag filter, a water manometer made from from clear plastic hose would work. Can be arranged for ΔP, or 2 separate ones and subtract, or if one side is at atmospheric pressure (eg blower suction) just 1 manometer is OK.
Cheers..........Codey
11/26/2010 7:12 AM
A Manometer is the same as a magnehelic device to read pressure drop across the filter media?
Good Answers: 137
11/26/2010 7:50 AM
I don't know what a magnehelic device is, but a simple manometer can be a length of flexible clear plastic tube, typically 6mm bore, bent into a U shape. Usually filled with water. You can clip it to a board and add a scale if you want.
Cheers.......Codey
11/29/2010 3:06 PM
Magnehelic is a brand name of a type of differential pressure measuring device.
It IS NOT the same as a manometer. It uses a bordon tube.
Dwyer Intrument makes the Magnehelic.
http://www.dwyer-inst.com/
Some standards are like the North Pole and some are like Mecca. People use both to get their sense of direction, however, only one is a preferred destination. - P.E. Scheibmeir
11/29/2010 4:24 PM
OK thanks I was not sure, I re-read my post and It was suppose to be in the form of a question and it doesn't due to using an A in lieu of Is. Thanks for clearing that up.
11/30/2010 8:43 AM
Dywer Instruments also makes Magnehelics that come with analog output modules that can be used for remote sensing of differential pressure.
Dywer Instruments are relatively inexspensive and provide decent service.
If your process is more mission critical, you might want to try Rosemont.
Acrylonitrile Butadiene Styrene (ABS)
11/26/2010 6:55 AM
Acrylonitrile Butadiene Styrene (ABS) is a common thermoplastic used to make light, rigid, molded products such as piping, for example, plastic pressure pipe systems, musical instruments most notably recorders and plastic clarinets, golf club heads - used for its good shock absorbance, automotive body parts, wheel covers, enclosures
Good Answers: 137
Re: Acrylonitrile Butadiene Styrene (ABS)
11/30/2010 9:14 AM
Yes, ABS is good stuff. Don't know what it's got to do with this thread, though.
Register to Reply 16 comments
Anonymous Poster (3); Codemaster (3); lyn (3); MrGeneRall (2); pipeit (2); rhkramer (2); shahpolymers (1)
