Previous in Forum: short circuit ratio(SCR)   Next in Forum: 33 kv substation
Sampling 11kva lines
11/26/2010 4:44 AM
Hello,
I want to know whether all the three 11kva lines are ok or not, for this I have to saple the 11kva lines before the transformers.
I really appreciate any help in this regard, Do we have any standard circuit for this or we have to design from basic.
Thank you
Re: Sampling 11kva lines
11/26/2010 5:41 AM
Dear student,
first, 11 kV or 11kva ?
please find out a power system book and read it. It covers all topics how to design with calculations.
11/26/2010 6:23 AM
Dear Sir,
Its 11KV lines which is input to the transmission transformers, Thanks for the information, if you can send some link I will go thro it.
Or if you have ready circuit, It will help me a lot.
Thank you much
11/28/2010 1:45 AM
11kV is not considered as transmission lines...It is primary distribution.....what is your question? sampling of 11kV lines??...cut a piece from the line for sample...be careful about smoke from your body
Good Answers: 131
11/30/2010 8:48 AM
Your 11kV distribution lines can be "sampled" using voltage (instrument) transformers with primary rated for your 11kV lines and secondary at 115V. The secondary goes to a meter or a voltage relay, that can indicate whether the circuit is above or below the minimum acceptable level.
http://www.electricityforum.com/products/potential-transformer.htm
Register to Reply 4 comments
Anonymous Poster (2); PeterT (1); tantarshan (1)
