Previous in Forum: Sampling 11kva lines   Next in Forum: Have solar panels improved
33 kv substation
11/26/2010 5:21 AM
which relays used for 33 kv busbar protection and how does it works.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
Re: 33 kv substation
11/26/2010 5:29 AM
For a 33kv SS we use many relays earth fault,over current,under voltage,phase failure etc. Depending on turns ratio of current transformer and PT the relay current limit is set. When a short circuit or earth fault occurs corresponding relay acts in turn opening the circuit breaker. It is done to isolate healthy part of system from faulty.
11/26/2010 10:50 AM
longtime delay relay,loose fault relay,short time extension relays, anti dry relay, wet sensing relay,
