Previous in Forum: Have solar panels improved   Next in Forum: Continuation Timeout (LF) in etap
10 comments
MILLIVOLT DROP TEST IN LT SWITCHGEAR/BUSDUCTS
11/26/2010 1:48 PM
Is there any Indian or Foreign Standard for measurement of millivolt drop & acceptable limits ratingwise in LT Switchgear/Switchboard/Busducts ?
Re: MILLIVOLT DROP TEST IN LT SWITCHGEAR/BUSDUCTS
11/28/2010 1:41 AM
Are you working in electrical industry??....Do you hear first time about voltage drop??...Why did you ask for millivolt drop?...Do you know what is milli, centi, kilo,micro etc?....Do you know about IEC, BS, NEC standards?..at least IS?....
11/29/2010 6:20 AM
It seems you are aware about everything in Electrical Industry. So please enlighten us by posting the relevant IS or any of the other Standards mentioned by you which clearly specifies the acceptable values of millivolt drop ratingwise. No vague clarifications please. For your kind information Voltage drop in LT Switchgear or Busducts are generally specified in millivolts as the figures are generally close to that unit ( NOT KILO OR MICRO ? ).
11/29/2010 8:37 AM
You dont need further enlightening on this subject. You already knows everything.
Register to Reply Off Topic (Score 10)
11/29/2010 11:11 AM
You already " knows " ???? It seems you require tuition in Basic English Grammar as well !!
11/30/2010 12:29 AM
Dear English professor, thanks for correction.I will make sure that you never get any good answer for any of your questions here in this forum.
11/30/2010 11:53 AM
Dear good student, I am shivering at your threat.... please dont be so unhelpful(as if you could help ??)
12/01/2010 12:12 AM
. CR4 ADMIN: Deleted Post
Vulgar/Rude/Improper Behavior: This post was deleted because it did not adhere to the behavioral policies of the site. Please review Section 14of the CR4 Site FAQ and the CR4 Rules of Conduct.
12/01/2010 12:31 AM
Very fine, shows your class....
12/01/2010 12:43 AM
The answers you got, shows the class of your brain. Get rid off from here,Nerd.
Good Answers: 11
12/03/2010 3:38 AM
Millivolt drop measurements on busbar joints are normally relative, so no typical values are given. It is for you on site to define the test and repeat as required. The exception is maybe specific equipment (ACB contacts for instance) where the manufacturer may give a guide value.
We normally assume that a joint should measure less than the equivalent length of bar, so you can easily work out an expected range. Bear in mind that readings will be affected by ambient temperature due to their sensitivity. Probe positioning will also be critical.
rogerggbr
Register to Reply 10 comments
Anonymous Poster (5); eccindia (4); rogerggbr (1)
You might be interested in: Panelboards and Switchgear, Cable Bus Systems
