Previous in Forum: Repad Diameter   Next in Forum: Non Destructive Test Education
Jib
11/27/2010 1:34 AM
hi. What is the difference b/w crane boom & jib.
Good Answers: 67
Re: Jib
11/27/2010 3:43 AM
You have not given the full form of b/w, I assume it as a gantry crane or EOT crane which is moving between two rails and loads to be handled should be between these two rails. So, its simply supported and having long travel, cross travel & hoisting mechanisms.
Jib crane is a cantilever crane, supported only on one side on a pivot, generally on a column at certain hight. It has cross travel from pivot (fulcrum) to the free end on the beam and angular travel of the beam w.r.t. fulcrum besides hoisting.
If the meaning of b/w is boom on wheel, then the difference would be mobile and static.
Re: Jib
11/27/2010 8:30 AM
What is b/w? Please don't tell me it's an "abbreviation" of between!
Good Answers: 114
Re: Jib
11/27/2010 8:47 AM
This should help. The boom is attached to the crane, the jib is attached to the other end of the boom. However, some people use the terms differently and cause confusion, context is most important.
Re: Jib
11/27/2010 10:35 AM
now tell him about the davit
Register to Reply 4 comments
lyn (1); passingtongreen (1); phoenix911 (1); pritam (1)
