Hi!
Need this info quick as possible so thx to everyone who is willing to spend some time to give me the right info.
I need to calculate what temperature would evolve in my system without a cooler.
What I did is this (I think this is wrong):
I calculated the total power loss in my system which came out to be around N=17 kW.
I tried to calculate the temperature with this formula:
T= (N/(kp*As) + Te
Where T is the temperature, N the power loss, kp the Thermal conductivity of the chosen oil tank, As the surface area of the tank, and Te the environment temperature.
The data for the chosen steel oil tank are
Volume = 375 L
Surface area of the tank = 2,98 m2
Heat dissipation = 1,44 kW (dissipation at (delta)T = 40 deg Celsius and kp (still air) = 0,012 kW/m2K.
As environment temperature I added 30 deg Celsius.
The temperature i get as result is above 500 deg Celsius.
Why I think this is wrong is this info about (delta) T being equal 40 deg Celsius. That should be the temperature value difference between the tank and the oil, shouldn't it?
The difference between the temperatures would be greater if the temperature is above 500 deg.C i think.
Am a bit lost here.
Thanks for helping me out.
