Previous in Forum: Energy Saving - 30hp Motor   Next in Forum: How to Protect Christmas Chasing Bulbs Set
Cable Size
12/01/2010 7:45 AM
dear cr4
please help me approximate result is acceptable.
Single phase lighting load
350m distance from source to load
110V ac
total load=500watt
approximate current=500/110=4.55A
I need size of cable?
what should be the size of cable?
asadmawa
Re: cable size
12/01/2010 8:07 AM
Search this Forum
Electrical Engineering:
Type "cable sizing" in the box to your right. It looks like the one above.
Re: Cable Size
12/01/2010 8:16 AM
<sigh> British Standard 7671.
Re: cable size
12/01/2010 8:17 AM
I'll just offer a hint (because I don't want to look up the appropriate tables myself).
There are two criteria to consider: the current must be less than the rated ampacity of the wire / cable (and insulation) to avoid a fire hazard, and the voltage drop must be such that the load can tolerate the voltage drop and / or relevant codes.
In your case, the voltage drop consideration will be the driver (well, at least under US codes (NEC: National Electric Code) it would be). IIRC (and I don't), I think the code calls for no more than a 3% voltage drop under load.
So, you need to:
  • determine whether the 3% limit is what you must design to (if not, what is the design criteria), then
  • determine (using Ohm's Law: E=IR) how many ohms of total resistance will cause a voltage drop corresponding to the limit that you must design to, and finally,
  • find a table of wire sizes and associated resistivity (per foot, or per 100 feet, or per meter, or whatever) and then determine what size wire is required to have a total resistance less than or equal to the total resistance allowed (from the previous step) (you need to consider the total resistance of both wires, and, at least in the US, you will need a third (grounding) conductor along with the two current carrying conductors.
Is this a temporary or a "permanent" installation? If temporary, there may be exceptions of some sort that might allow you to reduce the wire size determined.
Re: cable size
12/01/2010 8:32 AM
no its parmanent installation .I select cable 14 awg its current carrying capacity is 32 A
and 8.282 ohm/km,
so V=IRx2(neutral and phase)
so voltage drop=2x4.55 x8.282x350/1000 volts=26 Volts
but is this voltage drop is acceptable in engineering?
if ok i will use this if not please help me,
asadmawa
Re: cable size
12/01/2010 8:48 AM
see here.
http://www.youtube.com/watch?v=umDr0mPuyQc
Re: cable size
12/01/2010 10:16 AM
No, almost certainly not. It doesn't meet the 3% criteria for one, and if it is an incandescent light, powering it at 84 volts (110 - 26) will produce much less light (and probably red) than it would at 110 volts. (That drop is over 20%, isn't it (26 / 110).)
(If it is some other kind of light (HPS, CFL, I'm not sure what will happen--perhaps some of those can work at a much lower voltage (like 84 volts), but I suspect not, and I suspect there is some maximum voltage drop specified by your codes that you must not exceed.)
Re: cable size
12/02/2010 8:15 AM
As per the your specs
Rated Vol= 110V
Rated PW=500W
Length=350V
As per IEC voltage drop must be less than 2.5%
you must select 3CX 4 Sqmm Cable considering cables voltage drop(mv)/amp/meter is 10mv
sudip
Register to Reply 7 comments
Anonymous Poster (2); asadmawa (1); lyn (1); PWSlack (1); rhkramer (2)
