Previous in Forum: Sheath Voltages   Next in Forum: Statutory Bodies in Singapore
Assess ONAN 4.5 BGDxxx Spec C
12/03/2010 1:25 AM
I acquired this set last year, did some minor repairs, loadtested & calibrated it well, then installed it in my moho this spring. It performed well until after a 5-weeks sit-around. It was a moving-target 3 stages problem: 1- difficult to start; 2- very ragged running; and, 3- quit as soon as starter button is released. It moved through stages 1 & 2 in a couple of weeks & stabilized at stage 3.
By stage 3, I had eliminated fuel, carb, mechanical & ignition problems, and low oil pressure signal. But I hit the wall so sprung for the Onan diagnostics. An Onan tech found voltage was approx 60v, too low to trigger a "stay-running" relay. The tech found under 6 ohms resistance across the sliprings -- the spec range is 20.25 to 24.75 ohms, so it looks pretty open-and-shut. I later checked using a Fluke meter, it showed 15-19 ohms. There are no opens & no grounds.
Before I rush headlong into repairs, I want to know all needs so I have a realistic total budget upfront. So here's what else there is…
Voltage regulator for AC power passes the shop manual tests.
Beyond ensuring clean contacts, I do not see shop manual tests for circuit board A-1. Can anyone offer anything for testing parts of this board?
Stator seems good, no opens, no grounds, & all resistance check readings are far above the spec test values, cuz my cheap meter is not precise. I'm not keen to spend the bucks on a precise ohmmeter, so I have several Q's…
a. are stators inherently more reliable than rotors?
b. all readings of test pairs were above spec using the inadequate meter, & apparently there are no grounds & no shorts, so if I don't precisely measure the test pairs values, how much of a risk am I taking?
c. if I'm being reckless in the previous Q, then aren't there some tricks to measure ohms more precisely with an otherwise inadequate multimeter?
When I did the initial setup, the genset battery charge rectifier was not working. Since battery charging is also handled by the moho engine alternator and by the moho 120v battery management system, I reckoned this rectifier is redundant. But would this fault contribute to longer-term problems?
I also have a short in the genset electrics that is draining the coach batteries in a very few hours. What are the detective fundamentals of find & fix?
A non-Onan fellow who repairs Onan sets tells me his experience is Onan stators & rotors are nearly bulletproof, so be sure to verify the rotor is done before spending. I thought the above is conclusive, but are there any suggestions on further tests?
I will appreciate the wisdom of you experienced fellows, to help me to make good decisions. TKU all very much.
Re: Assess ONAN 4.5 BGDxxx Spec C
12/03/2010 11:57 PM
One question: When you measured the slip rings, did you measure across the slip rings themselves or through the brushes? I have a friend with an Onan MicroQuiet 4kW (KY series) in his rig and the one of the brushes was completely worn away after only 250 hours of operation.
After replacing the brushes and cleaning up the slip rings with some crocus cloth, his runs like a champ now. He had the symptom that it would start but die immediately after releasing the start button. He had intermittent problems for several months prior to it "dying".
The slip rings had some sort of black, non-conductive build-up on them that was also somewhat abrasive that accelerated the wear. He bought the regulator unit thinking that was the problem, so now he has a ready spare.
12/06/2010 11:48 PM
BSR...
Tx 4 your query. The Onan fellow removed the brush block & cleaned the sliprings. After I removed the genset & the rotor, I also ran the rotor through the dishwasher & airdried inside for a few days, so that's about as good as it gets. Don't tell the wife on me! (It cleaned up well, but there was only about a half-ohm increase in measured ohms. I did note on the outside wrap of the windings wire, the insulation coating appears to be cracked in quite a few places. Heat? Old age? Vibration?)
On the matter of improving accuracy of stator measurements, tonight I figured out how to do it with my cheap meter. (Its voltage measurements are decently precise.) For each "circuit" test pair, if I add a 15-ohm resistor & use a 9-v battery, from the spec R plus 15-ohm added R, I calc the current (constant around the circuit), then measure the voltage drop across the part of the circuit that is of interest, & from that, calc the resistance. If the calc result is close to the spec'd R value (say 10%?), then the test is good. If not close enough, do another iteration of the same calcs, but substituting calc'd resistance value into the spec'd value. Repeat the calc iterations as required to get to within a reasonable tolerance (10%?). Compare the last iteration result R to the required spec value. Slow, but it will save me the bucks for a precise ohmmeter that I use once only.
12/07/2010 12:00 PM
No need for precision on the rotor measurements. It is difficult to test for shorted windings by resistance alone because the relative difference in resistance between a good rotor and bad rotor are not that great, not to mention you can have short with degraded "connections" that measure close to the resistance spec. 10% is certainly close enough for most rotor measurements.
A better measurement is an impedance measurement that will give you the inductance of the rotor, but I have yet to see that information associated with equipment at this level.
As for the cracking of the coating on the windings, you can expect to see some "crazing" of the lacquer on older machines and a quick check with an ohmmeter should give you an idea whether it is simply a cosmetic issue or a potential short path if the copper is exposed. The lacquer may be multiple layers so it's possible you are only losing an outer layer.
The rotors are not cheap, (upwards of $200 or so) so I understand your deliberate pace.
12/07/2010 12:40 PM
BSR,
Tks again. I have accepted the rotor is toast unless a well experienced person offers an innovative idea. The spec is very clear with upper & lower limits for ohms. My rotor is seriously outside the range, so the 'crazing' is likely through the full depth of the winding with many internal shorts.
My perceived need for precision is in the stator, where spec values for resistance (across given pairs of connectors) varies from about 0.058 ohms to 2.1 ohms. A range is not given for these values, so maybe they are not critical, but I'd like to measure them with 'reasonable' accuracy & then make a judgment about whether or not I call Onan about them.
You are most optimistic on costs. Up here, all pieces are very costly, so I want to check as much as I can before proceeding... if nothing else, it gives me a better estimate of my costs before I start spending.
Thx again.
12/04/2010 12:03 AM
Hey folks,
Surely someone has some thoughts on my queries in this post?... I am hoping to learn a bit & especially, to benefit from your knowledge & experience! (I am a civeng, will address hydraulics problems, esp. pumps, open channels, pipe flow, some soils, plus miscellaneous, but now I need electrical guidance!)
TKU!
