Previous in Forum: Hardness & Surface Roughness   Next in Forum: S & P in Steel
Test on Transformer Oil
12/07/2010 4:48 AM
What is the frequency or criteria for carrying out the following tests on power transformer oil.
Furan Analysis
Dissolved Gas Analysis
PCB analysis
Re: Test on Transformer Oil
12/07/2010 10:04 AM
If all else fails, read the instructions.
Good Answers: 21
12/08/2010 6:51 AM
Depends on the end use of transformer and how heavily loaded it is. An example I use is Arc furnace xformers. These are in most cases run to the max allowed and then some if production can get one more once of steel out. I have these test done on a yearly basis. Some of the other units suppling power around the shop I only pull every couple of years. But, that depends on my main concern of what happens if I loose it. How does it affect production, cost of losing production and so on. Along with the oil testing, thermal imaging is a good idea. To look at your bushings and other connections as well.
Hope this helps.
Register to Reply 2 comments
