Previous in Forum: Electroless Nickel Plating   Next in Forum: USA iPhone, Blackbery Cases OEM/ODM
ptfe ram extrusion
12/07/2010 4:51 AM
how to make a simple ptfe ram extrusion machine for making 11 mm rod.
Re: ptfe ram extrusion
12/07/2010 9:52 AM
Here is "..a simple ptfe ram extrusion machine ..." Actually, I think the ram machine is made of HDPE or similar.
12/07/2010 10:09 AM
Doorman, You are such a cut-up.
chintan,
ptfe is a very difficult material to process. There is no simple way to do it. It takes a lot of heat and pressure to extrude it.
Is the 11mm a length or diameter? There might be an "easy" way to compression mold a rod. It would still take lots of heat and pressure.
Register to Reply 2 comments
