How to determine the correction factor for a transformer. For example, I have a 11/6.9kV transformer with correction factor of 0.45. Its given as ratio of no load to nominal voltage.explain me clearly if you are aware of it. Thank u
Hello friends, am not asking the value exactly. I have asked on basis of what factors you will determine the correction factor. You can come up with a good answer rather than typing its homework....
