Previous in Forum: Thermal Over Load Relay Setting   Next in Forum: Earthing Issue
How to Protect Electrical Circuit from Reverse Power
12/08/2010 12:24 AM
in automatic change over system how to protect the circuit from reverse power,in case of failure of auxiliary contacts of contactor.
Re: how to protect electrical circuit from reverse power
12/08/2010 12:45 AM
use diodes
12/08/2010 2:50 AM
very common pratise we are using in DG connection i.e reverse power relay..you may consider this also if the circuit is sensative and heavy
rgds
gst
United Kingdom - Member - British
12/08/2010 5:01 AM
Try some diodes in the circuit
bondy111
Re: How to Protect Electrical Circuit from Reverse Power
12/09/2010 3:23 PM
If you are talking about an automatic transfer switch the sources are separated, there is no potential for reverse power.
Good Answers: 170
12/10/2010 9:52 AM
Use Mechanical AND Electrical Inetrlocked Switching Devices.
01/10/2011 5:10 AM
its better to use reverse power relay if the circuit you consider is of heavy importance.
You don't understand anything until you learn it more than one way.
Register to Reply 6 comments
Anonymous Poster (2); Bondy111 (1); electricalexpert65 (1); norton850 (1); vijaymail_electrical (1)
