Previous in Forum: USA iPhone, Blackbery Cases OEM/ODM   Next in Forum: Working Silicon Bronze
Welding, Brazing, Joining to PCB
12/08/2010 10:26 AM
Hello all,
I need to somehow join a small diameter copper tube (.063 inch OD) to a copper pad on a circuit board. The board experiences high temperatures (> 250° C) so solder connections melt, even with higher temperature silver solder. I have been experimenting with a micro TIG welder, but it blows holes in the copper pad down to the PCB substrate. Have had similar issues, though not as severe, with laser welding. Have not tried brazing yet, but am concerned with it damaging the PCB or substrate. Any ideas on how to make a reliable connection (both electrical and structural)?
Pathfinder Tags: PCB high temperature joining
Re: Welding, Brazing, Joining to PCB
12/08/2010 10:43 AM
Anything here that might work.
http://www.shorinternational.com/Solders.php
12/08/2010 10:57 AM
"...high temperatures (> 250° C) so solder connections melt, even with higher temperature silver solder." Indalloy 165 maybe?
This tube: What is ID? Can a wire of proper size be connected mechanically to PCB, and the tube slid over and crimped?
Good Answers: 181
12/11/2010 6:47 AM
How does everything else stay attached to the board?
Register to Reply 3 comments
Doorman (1); kramarat (1); TonyS (1)
