Previous in Forum: Infromation Needed About Bird Caging in ACSR Conductors   Next in Forum: How to Calculate 3 Phase 11kV/415 Volts Transformer
Input Choke in VFD
12/09/2010 12:20 AM
Why fuse is used after input choke in vfd panels and whether it cannot be used before input choke.
Good Answers: 73
Re: Input Choke in VFD
12/09/2010 9:47 AM
Obviously the fuse is for protection against a short circuit. A choke is usually in series with everything else so it has no way of shorting to another power line unless it is of the design I saw for the first time yesterday where a three phase choke was wound on a toroidal core.
If the insulation of the choke wire melted, what would happen? That is one way of considering how it should be connected. But to be safe, the method of disconnecting the power to some cabinet should always be the first device encountered in any system that distributes power.
Hope that helps!
Good Answers: 50
12/12/2010 7:27 AM
Well. I would say that the fuse is normally before (supply side of) any VFD input options like RF filter, AC Choke etc.
What is the supply side protection for the choke, then?
Something new every day!
