Previous in Forum: Input Choke in VFD   Next in Forum: Transformer Query
How to Calculate 3 Phase 11kV/415 Volts Transformer
12/09/2010 12:49 AM
We require one 3 phase 11KV/415 volts Transformer for the following connected loads
3 phase,415 volts load 1500KW and single phase 230 volts AC load 300KW.can any body suggest the design calculations for Transformer.
Re: How to Calculate 3 Phase 11kV/415 Volts Transformer
12/09/2010 10:30 AM
If you plan to buy transformer,please tell the supplier/manufacturer of transformer.
India - Member - New Member
12/10/2010 7:41 AM
Give further details of 3 phase load. It must not be single load of 1500KW.
I mean No. of motors, heaters etc there ratings,
No. of starts for motor, Starting method of motor (DOL, VFD, Star/delta or Auto transformer etc)
Is 1 phase load distributed on all three phases?
It is difficult to answer with partial information provided by you.
When was last time you did something for first time.
Good Answers: 181
12/10/2010 8:48 AM
If you have to ask the question I doubt you are in a position to place the order for the transformer.
An engineer would have provided the relevant information in the OP, but by that virtue he would know the answer.
If this is a homework question, then look at it practically. IE by specifying a "standard" rated transformer, not by specifying a 1530KVA unit.
Register to Reply 3 comments
Anonymous Poster (1); Happy singh (1); TonyS (1)
