Previous in Forum: Area Calaculation of HVAC Duct Offset, Elbow, T-Elbow, Y-Elbow   Next in Forum: Wood / Coal Boiler Grate Material
Using Forge Material for Tube Sheet
12/13/2010 6:32 AM
hello everybody
i want to now if there is a code neccesity to use forg material for heat exchangers tube sheet or as a good practice engineering we usually use it and what is the reason we are not use plate fo tube sheet.
best wishes
alireza nazarian
Re: Using Forge Material for Tube Sheet
12/13/2010 10:42 AM
I don't know of such a code requirement, and have seen many tubesheets made of SA516-70 plate.
12/13/2010 11:18 AM
banu...
I assume that you are fabricating a shell-and-tube heat exchanger.
In most of the Western world, such devices are fabricated to a set of Codes and Standards. In the USA, S&THXs are fabricated in accordance with the ASME VIII pressure vessel code.
Within that code, the acceptable materials for tube sheets are listed.
What code are you using ?
12/14/2010 6:17 AM
we are using ASME VIII DIV 1 and TEMA class R for designing shell &tube heat exchangers but i didnt find anything about code requirement for using forg material.
thanks
