I recently changed my distributor on my 1998 dodge Dakota(because I broke off the bolt holding the cap on) and it hasn't run right since. I thought it might be a defective one so I returned it but same results. It will run alright until the truck gets warmed up or if I hit a bump it starts skipping and backfiring. Then it just gets worse untill it shuts off and it will not crank up for a couple hours. I have the repair manual and have followed all the instructions but no luck. When I put the dis. in like it says I have to turn it back counter clockwise just a little so the bolt hole will line up. When I do this the rotter button does not point to the #1 post on the dis. cap. If I put it in and its not on the compression stroke everything lines up perfect like it says it should on the compression stroke but the rotter button is way off. What should I do? Do I need to try and put the TDC off a little? Like between 0 and 1 or a little after 0 or what? Please help I have already taken it off and put it back 50 times!!! No lie.
