Previous in Forum: Insertion & Retention Force Gage   Next in Forum: Gas Header Pressure Balance
10 comments
Stair Case Pressurization Calculation
12/15/2010 1:04 AM
Hi fellow CR4's,
I'm a civil engineer and my boss ask me to calculate the staircase pressurization of the 2B+G+10+health club+roof residential building at dubai,U.A.E., How will I get he equation of the temperature factor,the standard outside air temperature and the stairwell air temperature?
By the way these project has two staircases one stair case will reach up to the roof level and the other staircase is only up to the health club level.
Thanks,
Rinus
Re: Stair Case Pressurization Calculation
12/15/2010 10:36 PM
This is the first time I'm ever hearing about staircase pressurization calculations. Are there lifts/ escalators for this building? Does the pressurization calculations apply to them also? What is the purpose of this pressurization calculations? Can it not be done with the simple barometric formulae?
12/22/2010 8:57 AM
Hello sam,
The purposed of pressurizing the staircase is to prevent the fire from going inside the stairshaft since during fire in high rise building the staircase are the main exits. This is mechanically operated by motorized fire dampers.
By the way have seen a high rise building without lift/elevator?
12/22/2010 9:12 AM
Hello Rinus, What I meant was, lifts and escalators go off service in case of fire. In some cases, escalators double up as staircases too. Is it necessary to maintain the pressure there also? I am ignorant on this subject
12/23/2010 2:02 AM
Hi Sam, It is not necessary to maintain the pressure in both lifts and escalators since during fire lifts and escalators are not allowed to used. Only fire marshals are authorized to use lifts.
12/23/2010 2:59 AM
Thanks Rinus for your reply. It has improved my knowledge. Thank you once again
12/16/2010 3:53 AM
This is first time I am coming across a CIVIL ENGINEER doing HVAC Calculation, please dont try you will end up confusing your boss, just tell him this is HVAC engineers job, Sorry ,In Gulf countries this is the way they work,
Thanks
12/16/2010 4:30 AM
There is procedures to do, required some parameters to do, and it should be done by HVAC engineers.
12/16/2010 4:50 AM
why calculate usually design pressure is 3-5 pascals
12/16/2010 4:55 AM
just make sure air distribution in all staircase diffuser are all of equal amount meaning you need air balancing and not only pressurizing the staircase u need also extraction because this is design for fire scape
12/16/2010 11:30 AM
Staircase pressurisation is required at the time of fire in the building to prevent fire to spread through it. Because staircase is used for exit from building as lifts will be in firemode. Normally staircase pressure is maintained at 3-5 Pascals by use of blowers, so that fire should not spred over it during opening of doors.
Hence there is no use of tamperature factor & ambient air temp as its pressure need to be maintained not its temperature.
Register to Reply 10 comments
Anonymous Poster (5); nirakar_prusty (1); Rinus Pegi (2); Samuel Chelliah (2)
