Previous in Forum: What's all this phony security stuff anyway?   Next in Forum: Illumination Software
AutoCad Command Line for 3D Rotate
12/15/2010 6:34 AM
I'm writing a procedure for design of water curtains. As part of this I'm using autocad to draw simple geometry then rotate it. When I use 3drotate command I select the geometry then select a base point. I do this just typing these into the command line. Then I have to pick an axis of rotation. I can do this by selecting say the y axis with the mouse but often it is not easy to see and tricky to pick up. Is there a command I can type into the command line to select the y axis? This would reduce potential errors as this is the axis the geometry will always rotate around in my case.
Thanks for any advice.
Good Answers: 29
Re: AutoCad Command Line for 3D Rotate
12/15/2010 8:53 AM
Select entity;
Type Y, enter;
Specify point on Y axis:<0,0,0>: enter
Good Answers: 29
12/15/2010 9:32 AM
Also you'll have to specify the second point on the Y axis. Sorry.
12/16/2010 6:23 AM
You could always put your rotational lines (as many as you want with different colours if you need) onto another layer and select it from there..Hope this helps..
Torque is not cheap
12/16/2010 8:00 AM
Command: _ucs
Current ucs name: *WORLD*
Specify origin of UCS or [Face/NAmed/OBject/Previous/View/World/X/Y/Z/ZAxis]
<World>: _3
Specify new origin point <0,0,0>:
Try working with your UCS. I use tools>>>new ucs>>>3 point (commandLineAbove) to pick points on my geometry so that I am rotating around the Z axis most of the time. The first point you pick is Z, next is your X axis, and the last point picked serves as your Y axis.
If you want to rotate around Y. Rotate your UCS around the X axis by 90 degrees so that Z is now your Y axis and then rotate your geometry with the RO commmand and select the object to rotate. (commandLineBelow)
Command: _ucs
<World>: x
Specify rotation angle about X axis <90>: 90
Command: ro
ROTATE
Current positive angle in UCS: ANGDIR=counterclockwise ANGBASE=0
Select objects:
Enjoy!
Anonymous Poster (1); merc600sec (1); RDGRNR (2)
