Previous in Forum: Sharing experience on Panasonic products in India   Next in Forum: LCD Projector
Underwater RC System
12/15/2010 1:43 PM
Could people use ultra high power FM27 Mhz transmitter and receiver to control under water vehicle over 40 feet deep? Any RC makers can make guarantee the signal can penetrate that deep. Regular RC submarine only can go down 10 feet or less? Well?
Pathfinder Tags: Underwater RC system
Good Answers: 145
Re: Underwater RC System
12/16/2010 5:22 AM
There are two problems.
1/ RC control units may only transmit at a certain power level as defined by the regulation. You are also restricted to certain frequencies as well.
2/ 27Mhz will not penetrate deeply into water as it gets absorbed quickly. You need to transmit at a much lower frequency say 300khz. However at this frequency the data rate is much much slower. This would lead to much time lag between instruction by the controller and the reciever/servo operating.
You could try to put more length on the submarines antenna to improve the reception.
You could increase the power of the transmitter by using a RF linear amplifier. However it may/will cause distress amongst other lake users by swamping their signals. It will also bring you to the attention of the communication regulators.
12/17/2010 12:36 AM
the RC radio's like the one you have listed are all but extinct. the technology has gone to spread specktrum 2.4 gig. one radio will not inter fear with another one. the distance ability is far Superior to the old Crystal systems. i would contact futaba or specktrum and ask them. i do not think any company would guarantee it,too many variables,like your batteries not being fully charged,or an in properly installed system.the receiver uses two antenna's that are to be set at different angles and distance. I had the DX-7,it was the best radio i ever owned.
anyone can F--*#@% up a design.It takes a good Man to fix it. Macgyverism at its best.
12/17/2010 1:22 PM
It's probably illegal to "use ultra high power FM27 Mhz transmitter ".
Register to Reply 3 comments
darren2264 (1); lyn (1); Tobugrynbak (1)
