Previous in Forum: Equivalent Material to ASTM A633 GRADE C with IS2062   Next in Forum: Brown & Sharpe Digit Cal II Battery Access and Button Functions
Method for Calculating Yield of DRI Production in Rotary Kiln
12/16/2010 3:58 AM
we would like to know the correct method for calculating the yield for working the production of Sponge Iron in a rotary kiln. we have been evaluating the yield for production using the following formula :
P = (Q-%TM)X(% Fe (T) in ore - % LOI -1/2 % L&P)
where
P = Production,
Q = Qty of ore used in the Kiln
Fe (T) = Total iron in the ore,
LOI = Loss on Ignition
TM = Moisture content &
L&P = Laterite and Porous material. (Impurities)
Pathfinder Tags: DRI
Good Answers: 299
Re: Method for Calculating Yield of DRI Production in Rotary Kiln
12/16/2010 2:47 PM
How does actual yield compare to your calculated yield?
Why only 1/2 of L&P? Is time not an important component or factor somewhere?
