i own a pre-fab steel building that has a structural steel framework setting on re-enforced concrete piers that are connected by re-enforced concrete grade beams. the building is enclosed with metal sheeting. the sheeting is attached with cadmium self-drilling screws that has a rubber washer to prevent water leakage. after five years, i've noticed that the metal roof sheets have deteriorated around the screws. i looks like it's caused by electrolysis. i've seen the same problem with buildings having fiberglass insulation between the sheets and the steel purlions "rafters". i've considered running a ground to a sacrafical metal "magnesium", then attach it to each column. i should mention that every steel member has a heavy coat of red "oxide?" paint between the bolted connections. any suggestions?
