Previous in Forum: Delay Timer Wiring   Next in Forum: Some Question About Gasket
Corner Welding
12/21/2010 4:19 AM
i want some refrance sheet for
edge prepration for `close corner weld'
Pathfinder Tags: welding corner joint
Re: corner welding
12/21/2010 6:26 AM
any data about corner flange welding????
any suggestion on corner flange welding...
please suggest
Good Answers: 21
Re: corner welding
12/21/2010 6:43 AM
That depends largely on what your making. If your welding a tank then you might consider one method. If your butt welding two plates then there is another method. What are you trying to make?
For an example: I built a new fuel tank for one of my aircraft. Corners are radiused and welds are made 1/2" from corner in the flat area and butt welded. This allows for a very strong corner and will not flex stressing welds or base metals.
More info and we can assist you.
Re: corner welding
12/26/2010 12:40 AM
hi i want to weld corne by the v grove with 2 mm land & 60 to 70 deg v grove
& fillet weld from the inside (stich weld 50(75)) length of the weld is 3meter
is it a right process to do.......& design required flush corner, otherwise i will gave the extra 10 mm & fillet weld on the corner...please suggest
Good Answers: 60
Re: Corner Welding
12/25/2010 9:26 AM
Re: Corner Welding
12/26/2010 12:43 AM
hi i want information about combination welds & there symbols.
fixitorelse (1); peterg7lyq (1); shaktishen (3)
