Previous in Forum: Corner Welding   Next in Forum: Machine Shop, What is it?
Some Question About Gasket
12/21/2010 9:34 PM
when i design a tank ,the specification date sheet show that vendor shall provide service gasket and bolting ,plus spares in accordance with related spec.
what is meaning of service gasket?
Re: some question about gasket
12/21/2010 11:10 PM
What is meaning of design a tank?
12/22/2010 2:38 AM
i am employed in chemical equipment manufacturing workshop and i am an engineer,and as you know we shall design drawing in terms of tank,heat exchanger ,tower and etc.
i design drawing for a tank.
Good Answers: 29
Re: Some Question About Gasket
12/22/2010 11:41 AM
Whatever goes in your tank must be supplied from somewhere by something. Is it possible that this process is being referred to by the vendor as service and that they think it will need a gasket?
Good Answers: 18
12/25/2010 6:01 PM
Jacky Lee,
I fail to understand you being the designer of the tank and being unaware of any componet of said tank? Maybe you need to supply more information to obtaine a useable answer.
Jerrell,
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
Good Answers: 181
01/01/2011 4:22 AM
Jacky, I think "I'm a design engineer" is wishful thinking. I've had a look at some of your previous posts.
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 27
01/07/2011 10:27 AM
This seems to be yet another one of those regretable "give a loaded pistol to a child" situations.
Nevertheless...
The service gasket is simply the gasket that will be used to seal the joint while the process is in operation.
Knock yourself out
Best regards, HeviiGuy
Register to Reply 6 comments
BoltIntegrity (1); Jacky LEE (1); Jerrell Conway (1); lyn (1); RDGRNR (1); TonyS (1)
