Previous in Forum: DG Set Consumption 25 KVA   Next in Forum: Minimum Hold Time for Hydro Test of Process Piping
25 hp DC Motor
12/22/2010 6:09 AM
sir i want to install a 25 hp dc motor for water pump. i want to know that 25 hp dc motor will be run 0n 10 200 amp batteries and how much time motor can work on 10 fully charged 200amp batteries
Re: 25 hp DC Motor
12/27/2010 12:41 AM
Assuming your DC motor run on 100V DC (most likely), and batteries are 12V type, your motor effieciency is 85%, and the motor capacity is 200Ah (not 200A):
Your best case with fully charged up batteries is
Current consumption = 25*746/0.85/100= 219 A.
Since the DC motor run on 100V , you will only be able to use 8 batteries in series at most to get 96V
So, your best case batteries will only last 200/219= 0.91 hour .
Bravo88.
United Kingdom - Member - British
Re: 25 hp DC Motor
12/28/2010 4:28 AM
Or 54.6 minutes
bondy111
