Previous in Forum: Actuator and Valve Question   Next in Forum: 25 hp DC Motor
DG Set Consumption 25 KVA
12/22/2010 5:02 AM
We have to run 25 KVA DG set for apartment lift (6 person lift) for 16 hours a day. It mostly runs on no load. As per thumb rule 25 KVA DG consumes about 5 lit/ hour on full load. Please can anyone tell how much it will consume per hour at no load (DG running but no load on it.
Pathfinder Tags: DG set
Re: DG Set Consumption 25 KVA
12/27/2010 8:15 AM
Assume, at no load condition, the engine will produce 4 kW
Diesel energy density is 39 MJ/Liter
5 L/hr is 5*39e6/3600= 54 kW
Assume Pf =1,
25kVA/54kW=0.46, your DG set efficiency is 46%
So, at no load, 4kW, power generated by DG is 4kW/.46=8695 W
= 8695*3600 J/ hr= 31.3 MJ /hr
31.3 MJ /hr is 31.3MJ/39MJ = 0.8 Liter/ hr
Bravo88
Singapore
01/16/2011 10:23 PM
Thanks Bravo88
Register to Reply 2 comments
You might be interested in: KVA Meters, Lift Tables, Lift Stations
