Previous in Forum: Auto Transformer MVA Rating   Next in Forum: DG Set Consumption 25 KVA
8 comments
Actuator and Valve Question
12/21/2010 4:13 PM
HI , I have a simple question regarding supply pressure actuator . I have recently bought double acting pneumatic actuator . The spec of the actuator , min pressure 120 bars , operating pressure 120/ 150 bars , design pressure 175 bars . Actuator BTO 27594 NM The valve that I'm going to use is size 24" 150 with torque BTO 12550 NM tested on 19 barg. Does this mean , the actuator will only perform in 120 bars ? Could I reduce the actuator supply pressure to around 50 bars just to meet the valve BTO 12550 NM. Does this Make any sense to you guys? Sarah
Pathfinder Tags: actuator
Re: Actuator and Valve Question
12/21/2010 8:07 PM
It looks as though some concepts are being mixed here. As for the 24" valve, what does the 19 bar specification represent? Line pressure, ΔP, or other? Also, I would be very leery of pneumatic actuation on such a valve. If there is a rough spot in its operation, an increase in the actuator pressure might slam the valve closed suddenly, risking liquid hammer.
12/21/2010 11:16 PM
Tornado , please abolish the 19 bar . The valve bto is 12500 NM . How much supply pressure do the actuator need to meet bto valve 12500 nm ?thanks
12/22/2010 4:55 AM
Minimum Pressure of 120 bar means that is the minimum pressure to operate on its specified torque and maybe to operate smoothly.
Reducing the pressure will reduce the developed NM torque, but also, it might not operate smoothly. Check with manufacturer or experiment!
12/22/2010 9:22 AM
I am just curious.
You say it is a pneumatic actuator and the design pressure is 175 bar and operating pressure is 120/150 bar.
Where are you getting this high pressure from.Are you using pipline gas,and what make actuators are these.
Thanks
If you don't know where you are going,you are bound to get there
12/22/2010 9:56 AM
Hi Sarah,
To get some kind of answer, we need to know the valve specs. If you have them in a pdf, you might be able to copy them and paste them right into the edit box here.
We would then have a much better idea of what you are dealing with.
If the actuator is pneumatic, I would think that standard plant air (6-7 barg) would be sufficient, even though your process pressure is much higher.
Mike
12/22/2010 10:14 AM
120 x 12550/27594 ≈ 54.6 bar, so in theory that might work; however, the actuator specification seems to call for 120 bar. This is unusually high, in my experience.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
12/22/2010 10:28 AM
My thoughts exactly, it is why I have refrained from posting anything. I do valves, pumps, piping, etc all the time and have never seen a pneumatic actuator that requires that high of a pressure to operate.
Sarah, which brand of valve are you using? What type of system is this for?
Sometimes my thoughts are in a degree of order so high even I don't get it...
12/22/2010 11:51 AM
you should talk to the producer of the actuator! Do not try to get answer from anybody else as this can blown your equipment to pieces.
Register to Reply 8 comments
Anonymous Poster (1); ChaoticIntellect (1); LAA_Lucke (1); Mikerho (1); Sarah_eng (1); srini (1); Tornado (2)
