Previous in Forum: scr or triac   Next in Forum: Insect repellent
18 comments
Relay Confi.
12/22/2010 8:56 AM
I need a relay rated 5V but i could only get a relay rated as 12V. Can anyone give a solution to make the coil of 12V relay work under 5V supply. I hope its possible with some circuit configuration.
Re: Relay confi.
12/22/2010 9:06 AM
Just about the only way would be to used a 5V/12V DC-DC converter (which would probably cost 5 or 10 times as much as your relay).
Sorry.
[ Oh, by the way,
From CR4 FAQ - rules for posting:
Do not post the same thread multiple times. The CR4 Admin will delete all but the most appropriate instance, or we may delete them all if we get sufficiently ticked. ]
Re: Relay confi.
12/22/2010 9:12 AM
It is possible to use a DC/DC converter to step up 5V to 12V. It will be cheaper to just buy a 5V coil relay. If you have 12V available then you could just use that voltage to power the coil and use a MOSFET with a gate threshold voltage (Vgs) of less than 3.5V to turn on the coil.
Re: Relay confi.
12/22/2010 9:53 AM
Whats the point of using MOSFET here if i got 12V i would have used it directly. Instead of buying a dc/dc converter why can't i design a voltage of 12VDC from 5VDC. Is it a foolish approach? Or should i make a converter here?
Reply Score 1 for Off Topic
Re: Relay confi.
12/22/2010 10:16 AM
Well I assumed that the reason you are using a relay is that you want to turn something ON and also OFF with some logic. I also assumed that your control logic operated on 5VDC. I see now that I made some foolish assumptions.
You most certainly can try to design a 5V to 12V step-up or boost converter. I've used the MC34063A without a problem. I recommend studying the application note that explains how to design a converter using this part.
I think that you'll find that using a 5V relay will be more cost effective.
If you're not intending to turn the relay OFF, why use a relay at all?
Re: Relay confi.
12/22/2010 8:05 PM
Your assumptions where right but if i use MOSFET than i need 12V supply for that separatly thats the reason i said so.
Re: Relay Confi.
12/22/2010 6:29 PM
Googling "5vdc relay" turned up 153,000 hits, with lots of suppliers. Electronics stores are perhaps more likely than automotive sources to have them. Rather than buying or making a converter, it will almost surely cost much less to get a relay of the correct voltage.
Good Answers: 116
Re: Relay Confi.
12/22/2010 7:48 PM
The following circuit shows a principle for turning on a 12 volt DC relay with a 5V DC supply. With switch S as drawn, the capacitor charges to near 5V. When S is switched over, the capacitor voltage is added to the supply voltage. To work, the 12v relay must actually pull-in at 9V which is often possible. The relay gets 4.5V always, which is probably above its release point! To overcome this, you could have another switch in the relay coil negative - which is only closed while the relay must be on.
There are variations, like connecting C to R permanently and making S single pole to positive.
Re: Relay Confi.
12/22/2010 8:02 PM
So 67model connecting a capacitor as you said solves the problem but i want switch S working itself.
Good Answers: 116
Re: Relay Confi.
12/23/2010 5:44 AM
You could use a vibration switch and sit back and wait for a passing truck or earthquake!
If you only need to energise relay a few times, following circuit is OK since only a pulse of current is drawn from the battery.
Re: Relay Confi.
12/23/2010 8:59 AM
Who are you..! You are designing circuits in seconds.how talented...!
Re: Relay Confi.
12/22/2010 8:42 PM
Clever idea, but to not use a relay to turn on a relay to charge the capacitor will require a transistor (MOSFET) bridge for a switch. I still believe that getting a 5V relay will be much easier.
Re: Relay Confi.
12/22/2010 9:11 PM
So the simplest way to get 12V from a 5V supply is to use a converter. I have seen cellphone charging from a 1.5V cell in a pen type device i hope thats a converter.
Re: Relay Confi.
12/22/2010 9:35 PM
No. The simplest way is not to use a converter; it is to get the right voltage of relay in the first place.
How many box tops do you have to send in to be an electronics engineer?
Re: Relay Confi.
12/23/2010 9:02 AM
Here ends the topic. 12V relay coil worked for 5V also.
Re: Relay Confi.
12/23/2010 9:07 AM
The simplest way to get anything done is to hire people to do your work. A cheap simple method is to ask for free advice, but you have to listen and you often get what you pay for. A monetarily cheap but valuable method because you add the value is to independently study a method described by the free advice. Particularly if the free advice includes some references.
Re: Relay Confi.
12/23/2010 11:35 AM
Redfred whats the secret. Are you smart or only in forum? So seeking advice is very inspiring to do especially when all are wrong,who bother about how cheap it is.
Reply Off Topic (Score 3)
Re: Relay Confi.
12/23/2010 5:07 PM
I've been called a "smart ass" by far more respected individuals than people who won't even give themselves a pseudonym. I've also had a Nobel laureate buy me a Guinness for helping him on his experiment. I've been wrong many times, that's how we learn. Some times people misunderstand me so they believe that I'm wrong.
One thing I am certain of though is that one of the key concerns every Engineer should consider is how much something will cost a project's budget. Remember, often the critical budget in a design is not the financial budget.
Re: Relay Confi.
12/24/2010 10:09 AM
"that's how we learn".
i like to hear it......you might have heard it before.....
go on....... i like you smart-ass.
Reply to Forum Thread 18 comments
67model (2); Anonymous Poster (8); JohnDG (1); redfred (5); Tornado (2)
