Previous in Forum: DG Set Generator Design:- One Bearing or Two Bearing?   Next in Forum: Magnetic Force Acting on a Ferromagnetic Material
Cost Analysis Among Three Power Backups
12/22/2010 9:39 AM
Hi engineers!
One customer has called me to give him a cost estimate(analysed and shown clearly) that will be involved in buying and installing power backup system amoung inverter/battery system,solar system and portable generator for his home during when the utility power goes off.The total load is about 500W and should run for 5hrs.
From my experience, I know that the portable generator will be relatively cheap(around USD 800) but involves running cost and disturbance,inverter/battery system will be a little high(USD 1,100) and solar system backup will be the highest(around USD 4000: 1Watt = USD 8-10,i.e material + installation).
Please help and if possible connect to me a link.
Best regards.
Estimate currency conversion
1USD = 1500TSH
Re: Cost Analysis Among Three Power Backups
12/22/2010 9:45 AM
This is the best solution. very cheap.
Good Answers: 804
12/22/2010 10:48 AM
Hmmm...
"Cost estimate" is a little too vague for my taste.
Installed cost? Operating cost? Long term cost of ownership?
Inverter / battery cost considerations:
  • Components (inverter, batteries, battery charger, cables, adequate framework to hold batteries (higher if in a seismic area), ventilation, effects of ventilation on HVAC system costs (if any)
  • Labor for installation
  • Cost of utility power to charge batteries and float them
  • Battery maintenance / replacement over time, including disposal
Solar PV system cost considerations:
  • Components (solar panels, inverter, cables, adequate framework to hold panels (higher if in a seismic or high wind area)
  • PV panel maintenance (cleaning), including replacement of dead / damaged panels, disposal.
  • ALL of the above costs for a inverter / battery system above
Generator system cost considerations:
  • Components (generator, transfer switch, cables, fuel storage facility, leak detection, level monitoring system, fire suppression system).
  • Fuel, delivery / transport, spill containment / mitigation, future clean up.
  • Generator maintenance (oil changes, cleaning, replacement parts, labor).
Good Answers: 58
12/22/2010 10:51 AM
You state the load will be 500W but do not state the voltage. Based on your currency conversion info, I will assume TSH = Tanzania - 230V @ 50Hz.
The following is based on a self starting, maintained system;
A generator will require a transfer switch, electric start on the gen-set, fuel supply and interconnecting conduit systems. Estimated Installed Cost: $7500.00
A solar system will require a solar array (collector), inverter, batteries, and related conduit systems. Estimated Installed Cost: $5500.00
A UPS System will require a place to mount it.
500 watts @ 230 volt for 5Hr will not require a huge capacity.
My choice would be a 750 to 1000 Watt UPS System.
The UPS vendor will be able to help you out with the required battery configuration to maintain back-up for 5 hours.
My estimate of a 750W - 230V - 50Hz UPS System with 5 hour reserve would be $700.00 to $1000.00 (USD).
Disclaimer: My dollar estimates are just that - estimates based on my local codes and vendor pricing.
A search on Google of "ups 750 watt 230 volt 50 Hz" is a good place to start looking.
Here is a link: http://www.google.com/search?q=ups+750+watt+230+volt+50+Hz&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&oe=
Hope this helps - Good Luck!
12/23/2010 8:49 AM
KJK!
Thank you for your comment,I real appriciate your response.
Best regards
12/23/2010 11:46 PM
Here are some generators, including some quiet RV (recreational vehicle) types of 1500 watts for about US$300.
http://duropower.com/?gclid=CJH1j5WIhKYCFRiAgwodlRFRqQ
For the small size of the load, a "transfer switch" could consist of a simple plug that would attach either to the generator or the grid, with no chance of cross-connection. You would want a pilot light still on the grid so you could tell when power is restored.
Ths is all manual, of course, but it looks pretty cost-effective.
Anonymous Poster (1); JRaef (1); KJK/USA (1); THOBIAS MABUGO (1); Tornado (1)
