Previous in Forum: Machine Shop, What is it?   Next in Forum: Mazak X510 2500 Watt Laser/Will It Cut Lead Plate
Calcium Carbonate Powder Manufacturing Using Ball Mill
12/23/2010 4:47 AM
Hey, I'm non-engineering person, looking for some answers of my questions. I am currently manufacturing calcium carbonate powder using ball mill with air classifiers as universally done. I am requiring high fineness, 97%=10 micron, 50%=2.5-3 micron. To get high results, I need to optimize my grinding in ball mill. Following are my details: Ball Mill Dimensions: 1.8m*5.8m (inner after linners) linners: ceramics Current Feed: 80% of 60 mesh Current Grinding Media: 25mm (3350 kgs), 30mm (3350 kgs), 50mm (400 kgs) Current Output from mill: 40% residue on 500 mesh & 30% residue on 325 mesh Please suggest me following: Optimum Media Charge Optimum Size of Media What should be residue from total mill output so that i can increase my production. Any help will be thankful! Regards
Good Answers: 69
Re: Calcium Carbonate Powder Manufacturing Using Ball Mill
12/23/2010 4:02 PM
Ask your equipment supplier, they will be happy to help you up-grade your mill, it means business for them, and for you.
Yahlasit
12/24/2010 12:51 AM
their help is not quite useful and that's the reason I've to research the solution myself.
12/24/2010 9:39 AM
Hi Merchant,
I never used ball-mills for dry powders. I made paint by grinding pigments and extenders as CaCO3 in some liquids, in paste form. Suugest a good lecture at:
www.im-mining/wp-content/themes/immining/pdfs/SensomagArticle.pdf
My question is, because dry powder ball-milling is very energy consuming, costly. Could you add water, grind, and dry when grind is obtained?
Wish you good luck in your endeavour and best holidays, Gil.
12/25/2010 1:41 PM
I AM A MERCHANT IN SUPPERFINE MARBLE POWDER, I WANT TO GO INTO PAINT PRODUCTION. CAN YOU ADVISE ME ON THE RELEVANT PIGMENTS,OTHER MIX AND NECESSARY EQUIPMENT SUITABLE FOR SMALL,MEDUIM PRODUCTION.
12/25/2010 2:50 PM
CAN I HAVE INFORMATION ABOUT PAINT PRODUCTION; MATERIALS AND MIX,EQUIPMENT FOR A SMALL MEDUIM PRODUCTION,PACKAGING e.t.c
01/14/2011 12:05 PM
Hi Jano,
What kind of paint you want to produce? House paints for retail or for contractors? What's the yearly volume?
When you have sales, everything can be made on high-speed mixer. Disperse pigments and extenders, add vehicle and additives, homogenize, and fill. When volume of production reach higher level, use a mixing tank separately after the dispersion, and before packaging.
If you need more, you have to pay for it, Gil.
01/16/2011 1:46 AM
Hi nhmerchant,
Thanks very much for your support ,but I need more so let me know what the deal is. I am not very well experienced in this field but I have the resource to commence production for selected market ( Building contractors ). I want to produce good quality paint out of crushed marble powder. I need to do it in a unique and small scale to acheive needed recognition before moving into a large scale by God's grace. Please let me consult you to determine the relevant technologies, picturial view of equipments, technical descriptions and where I could source them. My e-mail is ( anokam@ntlworld.com ) Thanks and kind regards.
J anokam.
Register to Reply 7 comments
Anonymous Poster (2); janokam1 (3); nhmerchant (1); Yahlasit (1)
