The NGR operation logic is so designed that if this happens, the NGR of a running generator is automatically turned ON.
Is it ok to ground body of NGR panel
I am not sure what do you mean by body of the NGR. IF you mean the resistance itself, the answer is NO. If it is the NGR panel or the structure of the NGR (which is not electrically connected to the NGR), then the answer is yes.
- MS
