Previous in Forum: Turbine Efficiency   Next in Forum: Used Tires Recycling
India - Member - New Member
Brake Horse Power
12/25/2010 5:49 AM
Dear all,
What is Brake Horse power?How do we calculate it ?
If a Pump/engine BHP is 10, can we use 10HP motor for it ?
When Emotions runs high ,Intellectual wont work
Good Answers: 60
Re: Brake Horse Power
12/25/2010 9:24 AM
Good Answers: 137
12/25/2010 6:54 PM
The "brake" bit is used to indicate the actual power drawn by the pump etc. It's based on the brake dynanometer used to measure output power of an engine etc. IMHO it doesn't really add anything to HP. At one time in Europe brake kW (bkW) was used, but I haven't seen that recently, just kW.
It's usual to add a margin to the power drawn by the pump in selecting the rated power of the motor. Also if power drawn is 10 HP at duty point it might be higher at other points on the pump curve, which the motor might need to cover.
Cheers.......Codey
Register to Reply 2 comments
