I have a doubt about the calculation of the capacity of a multistage reciprocating compressor.
In Mark's (14.3.21) it says that the capacity is equal to the displacement of the first stage, multiplied by the volumetric efficiency. But when I calculate displacement I already account for volumetric efficiency.
pi*D^2*L*N*Z*j*ev-pocket*ev-temp*ev-press*ev-leak
Q = ----------------------------------------------------------
where ev-leak is the volumetric efficiency itself. The other ev numbers are for different factors. N is the speed, Z the number of pistons in the stage and j is factor to account for double effect cylinders.
But in some solved problems I have seen (for multi-stage compressors) ev-leak^2
pi*D^2*L*N*Z*j*ev-pocket*ev-temp*ev-press*ev-leak^2
Q = ------------------------------------------------------------
But is simply doesn't make sense to me considering the square of ev-leak. If I were to account for ev-leak in every stage of the system, then I should also consider the other "efficiencies".
Do you know of any book that explains this stuff in detail?
